2005 Excursion A/C Problem
Old 07-09-2009 | 12:46 AM
tatman's Avatar
Default 2005 Excursion A/C Problem
Here recently, me digital climate control will randomly black out. When it does this I have no A/C. Also, when it is working, it seems as though it's not quite blowing as cold as it should be. I checked for leaks and coolant levels, and these appear fine. Help! it's too hot to be dealing with this. Thanks
Old 07-23-2009 | 06:45 AM
Use Common Sense's Avatar
You may need to replace the electronic climate control unit. Since it's blanking out, it also may not be registering the proper temperature setting(s). You may have it set down to 60, but the unit may on ly be registering 68 nad such.
bartlc
12-03-2011 08:57 PM
rbknisley
06-23-2011 01:40 AM
penz
10-30-2009 01:30 PM
larmak90
10-22-2007 10:46 AM
larmak90
10-22-2007 10:46 AM
