Ford ExcursionSo the size of the Expedition is not enough for you, then the massive Excursion is the way to go. With options including a powerful diesel engine, the Excursion is like a tractor trailer built for family use.
P1316 is for Injector Driver Module codes detected.. Could be harness/circuits, IDM ect.. Were there any other cylinder specific codes during a scan?? for high/low open/short?
no other codes was brought up on scan. i was wondering if this could have anything to do with having 1 bank of injectors changed. this code came up shortly after this.
I have the same thing. after all injectors, harness and valve cover gaskets were replaced. I get the ses light, code 1316 resets fine. truck runs fine no misses just comes on freq.
any new info would be great.
Thanks
