Popping Noise
Old 01-28-2007 | 09:39 PM
texasquail's Avatar
Default Popping Noise
I have a 2005 Ford Excursion Diesel, and everytime it goes from first to second gear there is a distinct popping noise. I can feel it under my left foot as I drive. I know that this is a common problem on Fords...but when I take it to the dealership, they never seem to know what to do? Any suggestions as to what this problem is? It is driving me crazy. Thank you-
Old 01-28-2007 | 11:31 PM
Default RE: Popping Noise
Sure its not the 2-3 upshift?
Old 01-29-2007 | 12:29 AM
texasquail's Avatar
That might be right....read that it may be the sway bar?
Old 01-29-2007 | 01:17 AM
Try and pay special attention to how many gear changes occur before you hear the 'pop' or clunk.. If it occurs between/during the 2-3 upshift, is concidered a normal function for the 5R110.. Not only on my own, but every 5R I've driven has had the clunk/pop to some degree if you pay 'enough' attention to the shifts.. Some worse then others (like mine) but will usually quiet after 3-4 sets of shifts as the unit heats up or with extended driving... May have a pattern, or re occur after a short 'sit time' with the engine off as well.. More so if the units cools.. Sometimes mine will pop/clunk after a 'set or two' of completed shifts after a trip on the highway.. Usually as mine,, the clunk seems to come from the floor area, but may have a bit of a 'bump' that accompanies the pop/clunk..
Some 5R100's have a clunk/pop on a roll away or launch (usually for R to D) at 2-3MPH.. Also concidered a noraml function....
bent-sideways
12-27-2010 01:13 AM
03expyeb
02-02-2008 05:23 PM
harr6607
08-11-2007 10:40 PM
Higgy1982
04-26-2007 02:34 AM
mad man
01-04-2006 04:17 PM
