Replace 3.73 Axles w/ 4.30 Axles?
Old 02-27-2007 | 01:39 AM
Survey's Avatar
Default Replace 3.73 Axles w/ 4.30 Axles?
I have an '04 Excursion EB 4x4 6.0 PS with 7" lift and 37" BFG's. My stock ring and pinion is a 3.73 ratio. I want to install a set of 4.30 ratio axles from a donor truck. Will 4.30 axles from other years bolt in to my Ex? Will SD truck axles work? Evidently the dealer never offered the 4.30 ratio with the diesel option. (too low I guess) The aftermarket only offers 4.10 and 4.56 ratios. I am concerned that 4.10 will not be low enough and 4.56 will be too low. Anyone got any ideas?
Troy78
08-01-2010 02:34 PM
jdubrr
01-26-2008 07:43 AM
91explorer12323
04-23-2007 04:01 AM
thinkinboutit
02-24-2007 11:10 AM
speedy431
11-20-2006 03:36 PM
