03 Expedition Vacuum Hubs
Old 04-03-2011 | 02:04 PM
schizm's Avatar
Default 03 Expedition Vacuum Hubs
Hello all, I have been lurking for some time. I have an 03 Expedition 4x4 E/B with a 5.4.
Recently it has developed a rattling sound at around 80kmh (50mph) that appears to be coming from the drivers side front, it also will not engage 4wd. The transfer case is shifting but the hubs do not engage. I jacked the front and spun the wheel and it also spins the axle when not running (no vacuum), after starting the engine the hubs disengage and the wheel spin freely without spinning the axle (vacuum). I removed the hose at the Vacuum and Emissions purge solenoid on the passenger side firewall and the hubs appear to engage while running. When I check the voltage at the plug to the solenoid it is around 12 volts when set to 2wd,when switched to 4hi it drops to around 8 volts.
Should the voltage at this plug be dropping to 0 volts when switched?
I don't know if the rattling sound is related to the hub engagent issue, anyone else experience this problem?
schizm
04-03-2011 03:00 PM
johno2355
02-09-2010 06:24 PM
rodent
12-08-2005 06:46 PM
mjsoliver
10-28-2005 05:22 AM
simplythomas
07-27-2005 05:55 PM
