2000 Expedition ABS activating when brake is applied
I have a 2000 Expedition and have the ABS light activatedand ABS grunts when brake is applied.hooked up the diagnostic box which gave a rear sensor code and module code. we replaced both and also a front wheel sensor with no luck! I even replaced the battery due to getting false readings on the box. after reseting the codes it continues to say rear wheel sensor and other none brake related issues.
What are the odds of the new rear sensor being bad or DOA?
$400 dollars later I'm getting upset with this ride!
garype
12-30-2007 10:59 AM
garype
12-30-2007 10:55 AM
