2001 Expedition blend door actuator
RE: 2001 Expedition blend door actuator
The Blend door actuator sits/screws to the top of the heater plenum.. Check for heated coolant flow through the heater core prior to any dash work..
Here's a pic of the blend motor..
[IMG]local://upfiles/6756/039BFB3EEE304E479C72E67C3DA05EAA.gif[/IMG]
[IMG]local://upfiles/6756/D98DA95A71CF4EAEB2AE04F21A729F8E.gif[/IMG]
Hayapower- Is this the same on a '98? Or should I be looking at the white plastic item bolted to the bottom of the heater plenum container in this case?
I have a '98 with the exact same problem the gentleman with the '01 describes.
Thanks.
Thanks.
cve
03-08-2017 07:15 PM
makuloco2000
10-03-2014 08:38 PM
