2003 Ford Expedition engine light stays on, what could be wrong?
Old 04-17-2009 | 01:46 PM
herbert's Avatar
Default 2003 Ford Expedition engine light stays on, what could be wrong?
Does anyone know why my engine light has been on since I purchased the vehicle two weeks ago. The whole ordeal has cost me so much that I can't afford a diagnositic check at this time. I would like to buy the part and fix it myself.
Old 04-17-2009 | 04:05 PM
Welcome to the site..
Most of the after market parts vendors like Kragen, Autozone ect. will read the trouble code at no cost to you.. If you can post the trouble code, it would help with a direction to go...
Old 04-17-2009 | 07:06 PM
FordChef85's Avatar
Default Engine Light
From my experience with fords throughout the years, if the vehicle is running good but the light is on, it could be the oxygen sensor is dirty or bad and causeing the fuel to over pump giving you lower gas mileage.
Old 04-18-2009 | 12:05 AM
herbert's Avatar
Thanks, I will go to Autozone tomorrow. There is a rattle sound coming from underneath the seat behind the passenger seat. It almost sounds like small rocks hitting thin metal, or like liquid is gurgling, do you know what I may need to replace or tighten?
Old 04-18-2009 | 12:11 AM
herbert's Avatar
Thanks, would that also make a gurgling sound under the passenger seat?
Old 04-18-2009 | 12:26 AM
herbert's Avatar
Default engine light
You are probably correct, I thought it might be the oxygen sensor. Where is it, because I was in a snow drift and the light has been on since, and I thought it might of got knocked loose.
Old 08-21-2012 | 10:07 PM
Her dog's Avatar
Default Yup o2 sensors...
I had the same prob drove it for months like that. Replaced the front 2 o2 sensors 47.99 a piece and cleared engine light runs great.
markf1971
09-14-2014 12:20 PM
livingstonroofsinc
05-31-2012 06:59 AM
Jonny.M101
04-01-2010 03:14 PM
393stroker
08-10-2007 04:47 PM
ranger#2
08-28-2006 08:11 PM
