2005 Ford Exped. Blown Starter Fuse?
Old 08-20-2007 | 09:57 PM
Robert1's Avatar
Default 2005 Ford Exped. Blown Starter Fuse?
Every time I star the ignition , the starter fuse blows. Have already checked the starter relay..it's ok. Have replaced the starter and still fuse blows. Have no idea what the problem is. Currently have an aircraft grade resetable fuse in place of the 30 amp maxi-fuse that came as the original equipment. Aircraft fuse has a small delay time, but it will now start and has not tripped the aircraft fuse yet. Any suggestions on what the underlying problem is????
Old 08-24-2007 | 10:03 PM
02greenF150's Avatar
Default RE: 2005 Ford Exped. Blown Starter Fuse?
Make sure the signal wire to the starter is not touching anything. if it grounds it will blow the fuse.
mholder
10-03-2011 07:03 PM
fw31100
09-22-2008 09:06 AM
fw31100
09-21-2008 09:13 PM
Philywilly03
01-19-2008 07:03 PM
jbish44
02-01-2007 05:30 PM
