2007+ Front Window Regulator Replacement
This has been a long time coming and I finally got one in and had time to record just how to replace the front window regulator on the 2007+ Expeditions and Navigators. This is an all too common issue and if you own one of these this will haunt you sooner than later. In this video I walk you through the procedure. Hope this helps.
