2010 Expedition
Old 11-03-2010 | 09:13 AM
dvskw's Avatar
Default 2010 Expedition
Remote start, should it cut the car off after opening the door.
Old 11-03-2010 | 09:46 AM
Mr.Fr33z3's Avatar
No, If it is the factory remote start, it will cut the engine if the brake pedal is pressed without the key in the ignition.
Old 11-04-2010 | 10:23 AM
dvskw's Avatar
The 2010 Expedition will cut off if you open the door of the car if it was remote started. You can not open the door without the car cutting off. This is a ford remote start that came on the car new. Called the ford dealer and they advised that it was fords better idea. The book said contact the dealer if it does this. Any idea on how to fix this. Thanks
Old 11-04-2010 | 10:35 AM
There must be some procedure that you can use with the remote start unit that would allow you to get into the vehicle without it shutting down, which is what you would expect it to do if the vehicle is being stolen.
Did you receive any driver's/ owner"s manual that would provide instructions regarding this procedure?
Old 11-04-2010 | 11:31 AM
dvskw's Avatar
No Hank, the manual says see dealer.
federalammo
08-09-2015 08:27 PM
Expedition-Limited
04-01-2014 09:55 AM
TimMickunas
09-25-2012 10:16 PM
dvskw
11-03-2010 09:07 AM
TheOldMan
11-01-2010 10:20 PM
