Air Ride to Coil Spring Conversion
Looking at doing the air ride to coil spring conversion in the rear of a 1998 Expedition XLT 4WD. I have read about the aftermarket kits, but also read about using Ford springs & isolators. Can I just use the regular variable rate coil springs from the 2WD Expeditions without air ride, and just put them in with new isolators?
RE: Air Ride to Coil Spring Conversion
Ok, so I figured it out. You use F7525560DA for the rear springs... and F7525536AA for the rear insulators/isolators. What I dont know, is what to use to cap off the air lines to the rear, so that the system still operates the fronts properly. What is everyone else doing?
letsbangout
05-23-2012 07:03 AM
1998, 98, air, coil, conversion, converting, epedition, expedition, f7525536aa, f7525560da, ford, forum, ride, spings, spring, springs
