air ride compressor not coming on
Old 06-26-2008 | 11:02 PM
smokinjoe909's Avatar
Default air ride compressor not coming on
is there a pressure switch in the compressor cause i have power to ride height sensors to the rear silonoid to rear and have power to my compressor but wont come on.i had to run a hot wire to the rear silonoid under drivers door on frame and a hot wire to the compressor to get rear end pupmed back up then i turned the switch off and it has been holding all day but still havent figured out what the heck is my problem...thanks for your time...joe
Old 06-28-2008 | 12:10 AM
jr78's Avatar
Default RE: air ride compressor not coming on
No pressure switch. What year is it as it may have a relay on the rad, support behind thepass sideheadlight.
Old 06-28-2008 | 04:27 PM
hi it is a 99 eddie bauer exp.there is a 4 wire plug going to compressor and if i use volt meter and use -(neg) on one of the post and touch the other 3 with +(pos) they have power and even the box behind headlight has power to it...
QCubed
04-06-2012 03:47 AM
QCubed
08-23-2011 07:08 PM
QCubed
08-23-2011 07:06 PM
scnole93
12-18-2008 10:53 PM
Naked and Famous
02-27-2008 04:45 PM
