Airbag light codes?
Airbag light codes?
I have a 2003 Expedition and I have a question about the airbag light. Every time the engine starts, the airbag light flashes 4 times - then a short pause - then flashes 2 more times. It goes through this cycle three or four times, then lights continuous for the rest of the trip. Any idea what this code means?
Thanks!
Thanks!
RE: Airbag light codes?
if you have an autozone or somewhere near that you can take your vehicleto and they can hook up a code reader and give you the actual code thats popping, if yournot sure if they will do it call first. typically this is a free service at autozone, others may do it for free as well.it would then be easier to diagnose and troubleshoot your problem.
I have the same truck same year, that happened 2 years ago there is an extended warrranty on all veivhles with airbags, I think it 5 years or 50,000 miles? Brought mine in and it was a bad seat ground for the belt connector, thay had to take the seat out to fix, nut it was free. I think my code was the same and then after all the flashes it stayed on full time unitl I turned off the engine.
________
NEVADA MEDICAL MARIJUANA
________
