Catalyst Question
RE: Catalyst Question
ORIGINAL: techmanbd
Probably more likely one of the o2 sensors.
ORIGINAL: AdvRob
I got the P0420 diag. code and was reading up on it in varoius places but can't seam to find what the "Bank 1" means? Doe I need to replace left/right front/back catalyst converters??
Thanks in advance!
Thanks in advance!
Ok I guess I will start with the sensors, gotta be cheaper tha a cat. Is there something online I could look at for the location, like a microfisch. Sorry im really into working on bikes and don't know much about newer trucks.
As Btexpress said, replacing the sensor will never fix that code. It means just what he said, cat effeciency, not sensor slow to respond or nor working. It means it is switching just like the O2 sensor just ahead of the cat, meaning, nothing is going on in the cat. Therefore the only repair is replace the cat, or in some instances, reprogram the PCM to ignore that code. [sm=mail.gif]
dominicc926
04-03-2013 05:50 AM
porterjohn054
11-11-2009 04:43 PM
