engine noise?
Old 09-14-2005 | 06:20 PM
Michele's Avatar
Default engine noise?
Guys - I have this bizzare noise coming from my driver's front right. I have a 5.4L 2001 and it sounds exactly like a JetLiner landing! It is constant except for the pitch. The pitch changes as the accelerator is depressed?
Any ideas?
Old 09-14-2005 | 06:52 PM
techmanbd's Avatar
Default RE: engine noise?
Did you put any mods on it for intake? Sounds like the throttle body area. Check around to make sure all the hosing for the intake are on properly.
If you happen to put a throttle body spacer then you will get that noise.
Old 09-14-2005 | 06:59 PM
Michele's Avatar
No, the car is stock, but I will check the hoses to the throttle body. Thanks!
Old 09-15-2005 | 06:56 PM
cctxfish's Avatar
heard of 2 things;
1. IAC valve making noise. &
2. MAF sensor making noise. good luck
Old 09-16-2005 | 01:34 AM
stang99x's Avatar
I'd put my money on the IAC valve
Old 09-16-2005 | 07:41 PM
pakus's Avatar
MAF has no moving parts and can not make noise unless something has passed the filter and entered the sensor
Old 09-17-2005 | 01:32 PM
hockeyhitman69's Avatar
tap on the iac is probably sticking,common problem
cleaning mis only a temp fix
Old 09-19-2005 | 12:30 AM
stang99x's Avatar
CHange the IAC valve and you'll be on your way
Old 09-19-2005 | 05:26 PM
cctxfish's Avatar
Pacus I agree, but some say it make noise. My money would be on IAC[sm=lockeddance.gif]
Old 10-03-2005 | 04:51 PM
Michele's Avatar
Uh, IAC is short for...?
Quick Reply: engine noise?
