help ,Expedition 2007
Old 03-15-2011 | 01:49 AM
sami's Avatar
Default help ,Expedition 2007
i would ask for a help for the following problems:
1- right mirror going up and down but not right left
2-liftgate door doesn't open with outside
release handle, i tried everything but no way starting from keyfob (no power liftgate system)
3-visor mirror lamp , left and right are not working.
4- the Radio frequency spacing is 2 by 2 , could could i change it to 1 by i
Old 03-15-2011 | 07:44 PM
The last time I got involved in a mirror job I recall there being two little electric motors in the mirror assy. They are of course reversible and that is how you get 4 directions of movement. I would start with the switch that sends the signal to the mirror motor in question. Depending on whether you have a signal (voltage) going into the switch and coming out when activated will determine your next course of action. Let us know if this was any help.
Not wanting to confuse you,
"Ford vehicles now have a front electronic module, a rear electronic module and a driver's door module."
Closing the switch sends the signal to the affected module which then sends the signal through the data bus to the module at the other end in this case the mirror or visor lamp or liftgate . This was done to reduce hard wiring.
Sometimes you need to find the modules in order to determine if they are receiving/responding to the signal.
Ratpack
03-11-2008 03:56 PM
badfish
02-28-2008 11:16 PM
ddsdenise
08-29-2007 04:50 PM
Ohio Bud
02-04-2007 04:53 AM
mike2001
01-30-2006 07:15 PM
Quick Reply: help ,Expedition 2007
