Help w/installing elelctric brake controller on 03
Old 03-06-2008 | 04:51 PM
Tom Schlichting's Avatar
Default Help w/installing elelctric brake controller on 03
I was looking for some help/advice on installing a electric brake controller on on 03 expedition. I have a brake controller to use that I had installed in a conversion van. In the manual is says "an electrical connector is provided under the intrument panel for installing a customer supplied electric brake controller" is also states that " a kit containing a wiring harness/adapter and installation instrucions to attach an electric brake controller may be obtained from a Ford dealer (part number 5A416). What does that mean? Where is the elelctrical conector provided under the instument panel located? what needs to be taken off and where do you find it and can I wire into it therewithout theadapter part number 5A416? or do you need that adapterto get the job done or make it a lot easier? is there an aftermarket adapter available or do you need the ford part? post here or email me at tom.schlichting@wolterskluwer.com
Thanks Tom
Old 03-06-2008 | 05:12 PM
Default RE: Help w/installing elelctric brake controller on 03
the 03does have both the 7wire round and 4 flat connector allready wired in the back
Davem
04-17-2008 12:08 AM
iamb4u
09-14-2007 03:35 AM
dee004
04-02-2007 08:26 PM
floyd
08-11-2006 01:29 AM
scott
07-25-2006 12:32 AM
Quick Reply: Help w/installing elelctric brake controller on 03
