keyless entry code????
It should tell you in the manual how to reset the codes. But just incase, if you look behind the dash (from the floor up) just above the steering colum you will see the control box for the locks. On the bottom facing you will be a sticker with a 5 or 6 digit code. That's the original code programed in the truck. You can use that code or follow the directions in the manual on how to make a personal code. Either way, you need the numbers on that box.
DeanoNC
01-06-2006 03:03 AM
