need some engine help please!!!!!
Old 12-01-2013 | 03:29 PM
medicman681's Avatar
Default need some engine help please!!!!!
I apologize if this is not the correct forum for this so if it aint let me know. I have a 2003 expedition 4.6 that I am trying to change the timing chain in. It was rattling bad so I pulled it down to put in a new set of chains ect. Here is the problem I run it up to top dead center before removing the chains and tensioners the drivers side cam was off a couple of links(probably why it was running rough) so I got the bright idea that after removing the tensioner on that side I would just try and move the cam to get it back where it should be well that didnt work now I have removed the chains ect and the cams have moved a little. the crankshaft is where it is suppose to be how do I get the cams back where they need to be before putting the new chains on. Sorry this is a first on one of these.Any help would be appreciated.
Draxxon
04-11-2015 09:41 PM
ranger gsi
10-02-2009 11:13 AM
rlzzz
01-26-2007 12:22 AM
therlinger
11-07-2006 12:39 AM
davequest
09-12-2006 04:16 AM
Quick Reply: need some engine help please!!!!!
