Oil Pressure gauge - 00 Expedition
Old 02-21-2007 | 01:45 PM
Frito15's Avatar
Default Oil Pressure gauge - 00 Expedition
My oil pressure gauge is fluctuating between no pressure and normal from start up until the vehicle warms up, which is generally less than one minute. I am trying to figure out why this would be occurring. Once the vehicle is warm, the gauge works just fine. I am thinking that it might be an oil sending unit.
Old 02-21-2007 | 04:48 PM
Default RE: Oil Pressure gauge - 00 Expedition
Theoil pressure gauge receives the oil pressure 'status' directly from the oil pressure switch. The gauge is a 'two-position' unit meaning that it will 'only' read 0 and NORMAL..
Connect a jumper wire (preferably a fused (5A) jumper wire) between the engine oil pressure switchharness connector(WH/RD), and ground the wire end.. The gauge should read Normal pressure if the sender is faulted.
[IMG]local://upfiles/6756/85029F5DC13B47C19426E9B5BAFB6278.gif[/IMG]
daveranger
07-23-2008 08:32 PM
ahorton
02-21-2008 04:58 PM
77Bronco
05-09-2007 01:51 PM
killgore101
11-03-2006 12:41 AM
ashclan
10-19-2005 05:40 AM
