Petcock/Radiator Drain 2001 Expedtion
Old 01-28-2008 | 09:03 PM
L2793's Avatar
Default Petcock/Radiator Drain 2001 Expedtion
Where is the petcock/radiator drain on a 2001 Expedition?
Old 01-31-2008 | 07:52 PM
L2793's Avatar
Default RE: Petcock/Radiator Drain 2001 Expedtion
Got lucky! I found the petcock/radiator drain on my 2001 Expedition.
It is located directly below the upper radiatorhose at the bottom of the radiator. The petcock is a six-sided nylon nut. The easiest access is from under the hood and you will need a 19mm open end wrench toopen the petcock.
expeditionph
11-14-2016 08:23 PM
tatdawg
09-29-2013 09:03 PM
matteson
03-30-2008 05:59 PM
factory310
04-28-2007 07:23 PM
matteson
07-09-2006 09:49 PM
