Turn signals acting up
Could someone please tell me if there is a relay to replace for my turn signals? My signals are acting up. Sometimes they work and sometimes they flash fast, or they will stay solid. Sometimes they do not flash at all. Whatever happens on the inside panel, it also happens with the exterior signals. I have found the fuse, but that is fine. 2003 Expedition.
RE: Turn signals acting up
I have basically the same question..I have'05 Expy and on mine, I'm getting a rapid signal when turning on the left signal...front left and dash flash fast, left rear doesn't flash at all...also no brake light on rear left...bulb looks good (filaments aren't blown)...checked the two fuses that the handbook indicates control the signal/brake lights...they are both good...is there a relay?...and if so, could this be the problem?...where is it located?...thanks!
