When Buying an Expedition...
What kinds of problems are common that I should look for. Are there common suspension problems, oil leaks, anything like that I should look for. I'm probably going to be buying a 97-99 within the next few weeks and basically plan to use it for towing 4 wheelers and occasionally cars.
Any advice would be greatly appreciated.
RE: When Buying an Expedition...
No major problem's with the Expedition's.When buying just keep your eye's and ear's open.[ul][*] Look for maintence condition's[*] Was it taken care or. look at all fluids.Belts tire's body.[*] Any fresh paint?It may have been in a major accedent![*] Road test it listen for noises not the radio.[*] Turn the key on is the check engine light on?[*] Start the engine see if the check engine light on?[*] Just use common sence when buying if you get a bad feeling about it dont buy it the bad feeling could last a long time.[*] You also may want to get a Car fax report to see the history.
[/ul]
[/ul]
