02 explorer intermittent cranking
Old 06-21-2006 | 12:06 PM
jim07bob's Avatar
Default 02 explorer intermittent cranking
I have a 02 explorer that has a intermittent cranking problem. About once a month the when you turn the key the starter will not turn. All the lights burn and don't go dim while trying to crank the veh. I have the warranty repair for this vehicle and it shows that it was having the same problem from almost the begining the veh. has 49000 miles now. I have owned the veh. for 15months and it has done this about 5 or 6 times any suggestions. I had it in the shop on one ocasion but nothing was found.
Old 06-21-2006 | 01:37 PM
Mulletman's Avatar
Default RE: 02 explorer intermittent cranking
Check the small signal wire on the starter. These are known for corrosion and will intermittantly cause a "no crank".
Old 06-21-2006 | 02:10 PM
a4angiel's Avatar
I just replaced the starter and cable in my '92. I would look at replacing the cable from the battery to the starter (which includes the signal wire mentioned by Mulletman). You can order one from AutoZone. I was experienceing some periodic weak starts. Since replacing the items, the starts have been nice and strong.
Old 06-22-2006 | 12:28 AM
jim07bob's Avatar
what about the anti theft system could it cause this problem?
Old 06-22-2006 | 11:43 PM
Mulletman's Avatar
Only if the theft light flashes real fast when it don't start. Then try moving the tilt column around and try again. I have seen the transponder that goes around the ignition to recieve the programmed key go bad.
MAJohns
02-15-2010 10:21 AM
Rangerj
01-13-2009 11:36 AM
dirty92504
02-23-2008 05:30 PM
jamminford
07-05-2007 08:48 AM
Rebel62
05-02-2005 05:24 PM
Quick Reply: 02 explorer intermittent cranking
