04 explorer No Start No fuel
ok '04 explorer has no crank, no fuel problem. I checked the starting system it all checks out from key to starter except the relay is not recieving a ground from the pcm. When I jumper the wire to a ground at the pcm (with the connector disconnected) it will crank but not start (maybe because the connector was unpluged)
When i jumper the starter solinoid (with a remote starter switch) it will crank over but not start. When i spray starter fluid in the intake it will start. I havent climbed under the truck to test for power at the pump because i thought it may be related to the ground prob
PCM-maybe
or
PATSII
thx for your time
PCM-maybe
or
PATSII
thx for your time
When you spray the intake doe it stay started or die when the spray runs out?
I'm no expert. Sounds like pats though. The jumping and bridging prob triggered it.
Death of pats should throw a code. Cant remember the code but. See if you can borrow one and test it. It can be done with your key in the ignition and the key corresponding to the borrowed pats in close proximity.
Timbo
04-18-2013 12:39 PM
NYCArmyWife
11-16-2008 01:29 PM
iownslaves
04-01-2008 07:03 PM
