04 Explorer xlt 4.0l v6 error codes P0172 & P0175
Old 06-24-2023 | 05:31 PM
Thefirebeast's Avatar
Default 04 Explorer xlt 4.0l v6 error codes P0172 & P0175
Hello, the end of my vehicle registration is quickly approaching so figured id try and get some help here.
I have error codes P0172 & P0175. I have replaced the MAF sensor, bank 1 sensor 2, and bank 2 sensor 2 but the codes came back after clearing them. Any ideas, from easiest to hardest?
Thanks!
2004 Explorer XLT 4L V6
SOLVED! ecm reset to clear fuel trim issues from flex fuel
Old 09-11-2023 | 04:20 PM
joelemus's Avatar
Have you noticed a rattle or ticking sound from the front or rear of the engine? The timing chain guide rails and tensioners will fail. Eventually, your engine will jump time. If it's really bad your pistons will run in to your valves leading to a very bad day.
Old 09-11-2023 | 04:28 PM
I have but my brother and his boss(both mechanics) claim my sounds not coming from the engine. Iv told them before about timing chain being a common issue. Will have it looked at elsewhere at some point
Evan09
07-12-2022 12:55 AM
diehardgator1
12-11-2013 08:21 PM
BigMike
08-12-2013 07:01 PM
steve69
02-16-2012 01:29 PM
jruf1984
03-18-2010 05:46 PM
