06 Explorer Eddie Bauer - keyless entry factory code location
RE: 06 Explorer Eddie Bauer - keyless entry factory code location
MINE WAS ON A STICKER IN THE BACK OF MY OWNERS MANUAL. I ALSO CALLED THE DEALER TO SEE IF I COULD HAVE THE FACTORY CODE ERASED BECAUSE I HAD GIVIN IT TO SOMEONE I NO LONGER TRUSTED BUT THEY SAID NO, THEY DID SAY HOWEVER THAT UNDERNEATH THE BODY ON SOMETHING UNDERNEATH THE CARRIAGE WOULD BE THE NUMBER FOR THE KEYLESS ENTRY CODE. OTHER THAN THAT THEY TOLD ME FOR SUCH AND SUCH DOLLAR AMOUNT THEY COULD RE INSTALL SOMETHING.
on a 06 explorer you can only retreive the factory code from the dealer hooking up a computer to the pcm and reading the factory set code from the entry module. then you can change it to whatever 5 digit code u want to, but the oiginal factory code will always still work, ussually the dealer will charge you a half an hours labor to get this code.
DeanoNC
01-06-2006 03:03 AM
