1991 Explorer
Old 08-14-2010 | 01:40 PM
Den's Avatar
Den
Question 1991 Explorer
1991 Explorer...transmission fluid blows out of fill tube on start up only after sitting over night. Any suggestions on cause or remedy?
Old 08-14-2010 | 05:45 PM
There was a problem at one time where the check valve in the front pump was faulty and allowed the converter to drainback after sitting a while. This required that the front pump be replaced. This required removal of the trans. If the vehicle will not move right away when started this could be the problem. Also was anything done to the trans that required fluid to be added ? How does the fluid level check out?,,,,,,,,hanky
Old 08-15-2010 | 07:40 AM
Den's Avatar
Den
Default 1991 Explorer
Thanks for the info...Hanky.
Sounds like you have pin pointed the problem. It does appear that the converter fluid is draining back into the trans. The vehicle won't move at first until the trans. pumps the fluid back into the trans. and with too much fluid in the trans...it blows out the fill tube. The fluid is at the full level...however I have to add fluid every few days due to the fluid blowing out the fill tube.
Den
Old 08-15-2010 | 07:44 AM
Den's Avatar
Den
Ooops!...I meant to say: (The vehicle won't move at first until the trans. pumps the fluid back into the converter.)
Den
Old 08-16-2010 | 09:02 AM
stclist111's Avatar
Sounds like you got your answer, but you could also check the modulator valve on the side of the trans, if it has one, if they go bad fluid backs up in the vac line! simple fix.
Jville808
10-21-2006 10:49 PM
retread
11-16-2005 12:36 PM
retread
09-08-2005 05:03 PM
Ford Man
04-05-2005 03:57 PM
hungover
01-06-2005 03:27 AM
Quick Reply: 1991 Explorer
