1994 Explorer Constant Chime Alarm
Old 09-18-2005 | 11:49 PM
ghostpoet's Avatar
Default 1994 Explorer Constant Chime Alarm
My 1994 Ford Explorer has a constant chime alarm even after the car is started and running. I can remove the fuse, but that kills my radio. Can anybody tell me what casues this and/or how to fix this? I would just cut the wires to the chime, but I don't know where it is.
Thank,
Mike
Old 09-23-2005 | 06:42 PM
Sabretooth's Avatar
Default RE: 1994 Explorer Constant Chime Alarm
My thought would be normally when you open the door and your keys are still in the ignition, a sensor makes it chime to tell you that you've left you're keys...I would start in that system to see whether there is a short or ground or something along those lines...
Old 09-25-2005 | 07:40 PM
hockeyhitman69's Avatar
if you have a air bag problem and it has the dash bulb burnt it will chime all the time as well but if your dome light is staying i would say a door switch
FordMan59
05-01-2009 04:25 PM
jjam20
10-28-2008 09:39 PM
jjam20
03-29-2008 03:32 PM
johndeere88
10-13-2007 08:13 AM
sardines311
02-24-2005 03:48 PM
