1997 Eddie B brake lights problem
Old 10-02-2013 | 07:39 PM
BBQJOE's Avatar
Default 1997 Eddie B brake lights problem
The check brake lamps message comes on.
No brake lamps, but running lamps work, so ground must be good.
Checked both left and right bulbs, both are good. Didn't do anything with 3rd lamp.
Checked inside fuses, all good. Checked power box fuses, all good.
Checked brake pedal switch, working. Checked brake switch for power, power there.
What's left?
Thanks in advance for any help.
Old 10-02-2013 | 08:26 PM
The multi-function switch on the steering column, also known as the signal lite switch.
Old 10-02-2013 | 10:50 PM
BBQJOE's Avatar
What about it?
Old 10-03-2013 | 06:52 AM
The signal/stop lite circuit goes through the multifunction switch. You may need to replace it.
BK1997EB
04-05-2008 08:20 PM
BK1997EB
04-01-2008 01:43 AM
BK1997EB
03-12-2008 11:14 PM
jimw
11-20-2007 07:38 AM
moonunitpurple
03-08-2007 10:51 AM
