2000 Explorer wierd a/c problem
Old 07-24-2010 | 11:42 AM
seano5150's Avatar
Question 2000 Explorer wierd a/c problem
My 2000 explorers a/c compressor works great at idle (ran it at idle for two hours). After driving a few miles compressor quits opperating. High and low pressures are 195 and 40. System evacuated and recharged to exacxt wieght. Pressure switches are fine. Could compressor be affected by RPM or engine heat ( enigine not running hot )?
Old 07-25-2010 | 06:50 PM
At this point we don't know if your problem is electrical, A/C clutch not engaging when it should or poor connection to clutch or something telling the control, like thermostat in cab, desired temp reached , cut-off. Unless someone has a definite known cause for this problem, this is what I would do. Run a wire from the A/C clutch itself to a test lite in the truck and drive it a while. If the compressor quits and the test lite stays on the clutch coil is opening internally. If the compressor quits and the test lite goes out you now know it is something in the wiring to the clutch which starts from the fuse panel thru inside controls to the pressure switch and on to the clutch. You have your work cut out for you.,,,,,,,,,,,,,hanky
russell_j2003
04-13-2010 05:57 PM
tat2kid2
09-15-2008 09:36 PM
Sooner0233
04-12-2008 07:50 AM
gt460
10-16-2007 08:32 AM
harmonica
04-27-2006 03:44 PM
