2002 won't go into 4 wheel drive
Hi All, I am new here. I have a 2002 and love it. I haven't had any real problems with it until now. This may be a easy fix? This is my first 4x4 and have no idea where to start.
It won't go into 4 wheel drive. The 4 wheel auto dosen't work either. When I push the high or low buttons nothing happens. Nothing at all, no lights, no noises, nothing.
The only things I have done to it is oil changes, new left front wheel hub (bad bearings)and I did pull the battery to clean the terminals.
Any help would be great.
Thanks,
Barry
Thanks,
Barry
RE: 2002 won't go into 4 wheel drive
Hi, you start by checking the fuses. There is two in the fuse box in the engine bay. Fuse #17 and 18, 20 amps each. Three fuses in the fuse box above and on the left side of the driver's feet. Fuses # 12,15 and 29, 5 amps each.
Nic.
Nic.
