2006 V6 Oil Warning Message Reset?
Old 10-19-2008 | 08:39 PM
3rdford's Avatar
Default 2006 V6 Oil Warning Message Reset?
Does anyone know how to reset the oil warning message? Irecently bought a 2006 Explorer. The change oil warning came on the other day. After two days, and a stern "oil change required" warning I changed the oil. I tried disconnecting the battery but no help. None of my past Expeditions had this warning.
Thanks.
Old 10-20-2008 | 06:53 AM
Use Common Sense's Avatar
Default RE: 2006 V6 Oil Warning Message Reset?
To reset the oil monitoring system to 100% after each oil change
[approximately 5,000 miles (8,000 km) or 180 days] perform the
following:
1. Enter SYSTEM CHECK to display
“HOLD RESET IF NEW OIL”.
2. Press and hold the RESET
control switch for more than 2
seconds. Oil life is set to 100% and
“OIL LIFE SET TO 100%” is
displayed.
Note:
To change oil life 100% miles value from 5,000 miles (8,000 km)
or 180 days to another value, refer to the
Oil Life Start Value selected
from the SETUP MENU in this section.
Old 10-21-2008 | 06:38 PM
3rdford's Avatar
Thank you, that worked perfect. My Haynes manual should arrive soon.
Ken
FordMart05
06-30-2015 04:19 AM
rod525
10-17-2014 04:23 AM
donmiller1
02-07-2007 08:55 PM
donmiller1
12-26-2006 09:24 PM
what2do
09-28-2005 12:27 AM
