92 Explorer wont start! Replaced solenoid!
My explorer wouldn't start. I would put the key in the ignition and turn it, then I would pop the hood and cross the solenoid to get it to start and it worked. So i was told i had to replace the fender mounted starter solenoid and I did that and I still have the same problem. I had my viper alarm removed and put a new battery. Still the same problem. I'm thinking it's my ignition switch. Please help. I'm not too familiar with this truck. Thanks!
RE: 92 Explorer wont start! Replaced solenoid!
Auto trans??
First,, does it not crank in both P and N if selected (if auto).. If it cranks in 'either or' position then the trans range sensor is bad.. If both trans range selections/positions are dead, then you can usually varify a bad ignition switch by testing for current/power to the 'small' lug on the solenoid if the ignition switch is moved to the start/crank position.. You can use a test light or meter to test for key/crank current at the solenoid..
ORIGINAL: nflz32
It runs and the starter does turn over when I cross the terminals at the solenoid. How would I use the test light? Sorry, I'm still learnin'. Thanks again!
Sterling_Six
09-19-2008 11:06 PM
