96 explorer turn signal
Old 01-31-2006 | 07:15 PM
sntidesne's Avatar
Default 96 explorer turn signal
ok my problem is that every time i try to put on the right turn signal on by pushing the lever up it just buzzes and dosent turn on the light but if i dont lock the turn signal on it works fine any suggestions
Old 02-01-2006 | 07:16 PM
hockeyhitman69's Avatar
Default RE: 96 explorer turn signal
do you happen to have tilt steering
Old 02-06-2006 | 09:50 PM
sntidesne's Avatar
yes
Old 02-07-2006 | 05:50 PM
fordge48's Avatar
I just repaired the same problem on my 96 Explorer.
The grease around the contacts in the column has dried up and the contacts are corroded.
You will have to remove the module, clean the contacts and lightly apply an electrical lube(grease)
Old 02-08-2006 | 12:43 AM
sntidesne's Avatar
how do i go about getting the module out where is it located
Glowbug
01-28-2022 01:43 PM
gbiemer
09-24-2009 03:14 PM
pixleyyy
03-28-2007 12:08 AM
harlem
01-16-2006 04:35 AM
bingermann
10-31-2005 02:36 PM
