97 XLT : Check Engine light will not read
My wife's 97 XLTs check engine light is on so I took it to Auto Zone today to have it read and the reader would not read it or reset it. It has come on before and then went off on its own so I am as concerned about checking the port to make sure that it is working as I am the actual codes. How can I make sure that the port is actually working?
Thanks,
Randy
Thanks,
Randy
Problem Solved, Thanks
You are absolutely right it was fuse #5 on the inside panel. I was able to get the code read and cleared at Advance Auto Parts . The problem the code turned up will be a bit more expensive though, it was the catalytic converter.
Thanks,
Randy
Thanks,
Randy
