99' Explorer - Slow
Old 03-16-2013 | 11:29 AM
Mr. Plow's Avatar
Default 99' Explorer - Slow
Hey everyone,
Did a tune up not too long ago, changed coil pack, new exhaust. It runs good but keeps throwing a random misfire pretty often. When im in town at a light it starts pulsing pretty hard, i gotta keep on the brake, the lights pulse with it going from dim to normal. Sometimes it just won't start but I found a trick for that, if I peg the throttle to the floor and let it turn over for a while it will fire up. My main problem is it seems like its missing alot of power. When i come to a hill, 30mph up it and it won't go any faster. I took about a 1/4 inch of slack out of the throttle cable, that helped with the kickdown a little bit but that's about it. Not sure what I should be getting on gas milage but I get about 13-14 mpg on the highway. Leaks oil. My friend has a Snap-On Solus Pro code reader, I got to figure out how to use it though, not sure how helpful it will be.
Any ideas or where can i start???
Old 03-16-2013 | 04:08 PM
You can try to see if there are any codes in there, but what you need to see is what we refer to as live data stream. Things like TPS, Short term fuel trim and long term fuel trim at idle and 2500 RPM. EGR function, coolant temp, and possibly a misfire code. Let us know what you find.
Old 03-23-2013 | 01:09 AM
Mr. Plow's Avatar
Thanks,
Ok, will do when I get the chance. Well I know it's not the TPS because I just replaced that not long ago. The MAF sensor I wasn't sure about so I sprayed that with some rubbing alcohol to clean it. I remember when I got the new TPS I got excited and went ahead and tried to install it in the parking lot but the screws were so tight on there I said forget it till I get home and get it. But I got down the road and the explorer was running bad, remembered that I forgot to plug the sensor back in! For whatever reason that day I was checking over the fuses and found a blown HO2 fuse, I imagine that it was from the TPS being unhooked, replaced it, haven't checked fuses again since.
I've been small talkin with other people, a couple people have said it could be a plugged catalytic converter causing the loss of power.
Old 03-23-2013 | 11:01 PM
bluewind's Avatar
There are several ways to diagnose a plugged catalytic converter. Measuring back pressure would be one.
you could also try a catalytic converter cleaning using lacquer thinner (not paint thinner!)
by the way i don't like to use anything else but dedicated MAF sensor cleaner on the MAF sensor. rubbing alcohol is only so many % methanol. The rest is water of dubious quality.
Old 04-04-2013 | 11:36 AM
Mr. Plow's Avatar
Ok, Haven't done anything yet. The guy I know that has the code reader was behind me going over the mountain one day and he said hey I know what your problem is its your cat. converter I can smell it big time.
Today couldn't get over 30mph trying to get up this big hill and when i got to the top I caught a wiff of that heat smell. This is a pretty common deal for me.
The thing is though is it has two cat.s and one of them is angled I think. I would hate to punch out those cats and have that not even be the problem, I would like to cut them out and weld a piece of pipe in, test drive it for a couple of days untill the new cats come in. But we will see.
Why would it not throw a code though? The only code that comes up for it is a random misfire. Is it just because the O2 sensors are compensating for it?
Old 04-05-2013 | 02:51 PM
Mr. Plow's Avatar
All the data below is just while it was idling. Some numbers fluctuated a lot during the live stream such as SFTrim going into negative numbers (-9 to about 0 back and forth) during idle, and of course the RPM.
Pending Codes
P0300 – Random Misfire
Test: KOER
** Engine Running Codes – Fix Second **
P1127 HO2S Downstream Sensors not Tested
Snap shot of Live Data Streams:
[O2 Sensors]
HO2S11(mA)__________________512
HO2S12(mA)__________________852
HO2S21(mA)__________________473
HO2S22(mA)__________________906
HTR11_______________________ON
HTR11A______________________OFF
HTR12Fault___________________NO
HTR12_______________________ON
HTR12A______________________OFF
HTR21_______________________ON
HTR21A______________________OFF
HTRFAULT____________________NO
HTR22_______________________ON
HTR22A______________________OFF
HTRFault_____________________NO
HTRX1_______________________OFF
HTRX2_______________________OFF
CASEGND____________________-0.134
DTC Count____________________1
[FUEL]
Fuel LvlINP(v)____________________2.02
Fuel LvlINP(%)___________________60
FP (%)__________________________100.00
Fuel Tank Prs____________________2.84
TPREL(v)________________________0.99
FPFault_________________________NO
FPMoniter_______________________ON
[Transmission]
TCC(%)__________________________0
ElecPrsctrl_______________________179
EPC(v)__________________________9.09
Outsftsp(RPM)____________________0
TCCMACT_______________________14
TPNFluidtmp(v)___________________1.81
TFT(°C)__________________________51
[EMISSIONS]
EGRVR(%)__________________________0
EVAPCV(%)_________________________0
TPREL(v)___________________________0.99
Air Moniter________________________OFF
EGRFOPEN_________________________NO
EGRFSHORT________________________NO
EVAPVM___________________________OFF
EVAPCM(%)________________________0.0
FTP(v)_____________________________2.84
FTFFAULT__________________________NO
[DRIVEABILITY]
RPM______________________________736
DTC COUNT________________________1
TP(v)____________________________0.99
LOAD(%)_________________________15
BARO(kpo)_________________________78
BARO(hz)__________________________138
ECT(°C)____________________________78
ECT(v)_____________________________0.89
IAC(%)_____________________________29
IAT(v)_____________________________2.61
IAT(°C)____________________________29
O2S11(mv)_________________________732
O2S21(mv)_________________________728
LFTRIM1(%)________________________11
LFTRIM2(%)________________________9
SFTRIM1(%)________________________0
SFTRIM2(%)_________________________1
O2S12(mv)_________________________747
O2S22(mv)_________________________712
FUELPW1(ms)_______________________4.4
FUELPW2(ms)_______________________4.3
MAF(gmls)__________________________4.85
MAF(v)_____________________________0.95
FUEL STATUS________________________CL
SPKADV(v)__________________________0.98
EVAPPRGFLW(v)_____________________0.35
RPMDES____________________________656
THRPOSMODE________________________C/T
VBATT(v)___________________________13.8
VEHSIDSASR_________________________0
CASeGND(v)_________________________-0.124
IACFAULT____________________________NO
LOOP_______________________________CLSD
MISFIRE_____________________________NO
OCTADJ_____________________________CLSD
Old 04-05-2013 | 08:00 PM
I would lean toward the converter on bank 2 .I hate to put it this way, but I could be half wrong. The rich condition at bank 2 tells me that there is not enough oxygen there to complete the burn in the cyls there. It would help if you could also provide the data at 2500 rpm. Can you do that?
Old 05-15-2013 | 12:48 PM
Mr. Plow's Avatar
[O2 Sensors]
RPM__________________________2548
Loop__________________________CLSD
O2S11(mV)_____________________839
O2S21(mV)_____________________86
O2S12(mV)_____________________824
O2S22(mV)_____________________746
SFTrim1(%)_____________________0
SFTrim2(%)_____________________-2
LFTrim1(%)_____________________-1
LFTrim2(%)______________________1
FuelPw1(mS)____________________3.8
FuelPw2(mS)____________________3.6
Ho2S11(mA)____________________512
Ho2S12(mA)____________________914
Ho2S21(mA)____________________477
Ho2S22________________________922
HTR11_________________________ON
HTR11A________________________OFF
HTR11Fault_____________________NO
HTR12_________________________ON
HTR12A________________________OFF
HTR12 Fault_____________________NO
HTR21_________________________ON
HTR21A________________________OFF
HTR21Fault_____________________NO
HTR22_________________________ON
HTR22A________________________OFF
HTR22Fault_____________________NO
HTRX1_________________________OFF
HTRX2_________________________OFF
CASeGND(v)___________­_________-0.183
DCT COUNT_____________________3
ECT(°C)_________________________77
LOAD(%)________________________15
TP(v)___________________________1.23
[Fuel]
RPM_______________________________2468
DTC Count__________________________3
TP(v)_______________________________1.20
LOAD(%)____________________________15
IAT(°C)_____________________________34
O2S11(mV)__________________________71
O2S21(mV)__________________________674
LFTrim1(%)__________________________0
LFTrim2(%)_____________________________2
SFTrim1(%)_____________________________6
SFTrim2(%)_____________________________-4
O2S12(mV)_____________________________790
O2S22(mV)_____________________________769
FuelPW1_______________________________3.3
FuelPW2_______________________________3.2
MAF(v)________________________________1.73
MAF(gn/s)______________________________14.41
FuelStatus______________________________CL
SPRKADV(°)_____________________________33
FuellvlInp(v)____________________________1.21
FuellvlInp(%)____________________________33
FP(%)_________________________________100.00
Fuel TankPRS(v)_________________________2.80
RPM DES_______________________________656
TPREL(v)________________________________.98
thrPosmode_____________________________P/T
Casegnd(v)_____________________________-0.173
FPFault________________________________NO
FPmoniter______________________________ON
IACFAULT______________________________NO
INMANRUNCTRL_________________________OFF
[Emissions]
RPM________________________________2440
DTC_________________________________
ECT(v)_______________________________.84
ECT(°C)______________________________80
IAC(%)_______________________________43
IAT(V)_______________________________2.51
IAT(°C)______________________________31
DPFE(v)______________________________.94
EGRV(%)_____________________________0
EVAPCV(%)___________________________0
EVAPPrgFlw(v)________________________.39
RPMDES_____________________________650
TPREL(v)_____________________________.98
ThrPosMode_________________________P/T
DriveCount__________________________148
TripCount___________________________0
CASeGND(v)__________________________-0.173
Airmoniter___________________________OFF
EGRFOPEN___________________________NO
EGRFSHORT__________________________NO
EVAPCP______________________________OFF
EVAPCVFAULT_________________________NO
EVAPPVM(%)__________________________100.00
FTP(v)________________________________2.80
FTFAULT______________________________NO
IACFAULT_____________________________NO
Inmanctrl_____________________________OFF
INJ(1-6)FAULT__________________________NO
LOOP_________________________________CLSD
OCT ADJ_______________________________CLSD
Misfire________________________________NO
TRIP__________________________________NO
[DRIVEABILITY]
RPM________________________________2667
DTCCount___________________________3
TP(v)________________________________1.23
LOAD(%)_____________________________16
BARO(KPA)___________________________81
BARO(Hz)____________________________141
ECT(°C)______________________________79
ECT(v)_______________________________0.86
IAC(%)_______________________________42
IAT(v)________________________________2.97
IAT(°C)_______________________________21
O2S21(mV)___________________________568
O2S22(mV)___________________________783
LFTRIM1(%)___________________________-2
LFTRIM2(%)___________________________0
SFTRIM1(%)___________________________2
SFTRIM2(%)___________________________4
O2S12(mV)____________________________511
O2S22(mV)____________________________516
FuelPW1(MS)__________________________3.2
FuelPW2(MS)__________________________3.2
MAF(gm/s)____________________________16.16
MAF(v)_______________________________1.84
SPRKADV(°)____________________________35
EVAPPRGFLW(v)________________________.34
DPE(v)________________________________.93
RPMDES_______________________________656
VBATT(v)______________________________13.3
CaseGND(v)____________________________-0.183
[Transmission]
RPM____________________________2664
DTCCount_______________________3
TP(v)____________________________1.23
ECT(°)___________________________78
ELECPRSctrl(KPA)__________________176
EPC(v)___________________________8.74
FCCACT(RPM)_____________________
TCCMACT(RPM)____________________8
Trnfluidtmp(v)_____________________1.90
TFT(°)____________________________48
Gear_____________________________1st
Transrange________________________P/N
Transrange_D______________________0000
Transrange(v)______________________.01
TurbspdS(RPM)_____________________2672
ShiftS11___________________________ON
ShiftS2____________________________OFF
ShiftS3____________________________OFF
Eligee1
01-10-2012 10:04 PM
Fewer53
01-30-2006 03:38 AM
nss8425
10-26-2005 07:11 PM
ESCORTSRUS1989
07-04-2005 02:06 PM
daveranger
04-22-2005 05:48 PM
