99' Ford Explorer starting issues ?
Old 07-31-2006 | 06:29 PM
Allnbrgdn's Avatar
Default 99' Ford Explorer starting issues ?
My Explorer will only start when I have the gas pressed and when I let the gas go it shuts off can someone help please?
Old 07-31-2006 | 08:50 PM
94 4x4 ranger's Avatar
Default RE: 99' Ford Explorer starting issues ?
Sounds like a vacuum leak. Check the vacuum lines for crack's and make sure the line's are connected. When it run's is the check engine light on?
Old 07-31-2006 | 09:38 PM
Allnbrgdn's Avatar
no lights, just wont start unless I give it gas, and the only way it will stay running is if I keep giving it gas, I let go It dies ?????????
Old 07-31-2006 | 09:49 PM
When you get it running how does it sound?? Any poping ?Or is it running rough?
Old 07-31-2006 | 09:58 PM
Allnbrgdn's Avatar
No it seems to rev up fine
Old 07-31-2006 | 10:05 PM
Did you check the vacuum lines? Any loose wires?
Old 07-31-2006 | 10:11 PM
Allnbrgdn's Avatar
I did...... but I really dont know much, everything seemed fine.
Old 07-31-2006 | 10:15 PM
Ok im stumped.Mabey somone else can help.
Old 07-31-2006 | 10:19 PM
Allnbrgdn's Avatar
I just had a mech. clean the throttle body, could that be involved, what could be some problems, please help!!!!!!!!!!
Old 08-05-2006 | 12:51 AM
JasonVladescu's Avatar
Hey, I had the same problem a couple month ago on my 99 Explorer.
I had the IAC (idle air control) valve motor replaced. It was about $120.00 with labor.
hope this helps
Quick Reply: 99' Ford Explorer starting issues ?
