99' Ford Explorer starting issues ?
Old 08-08-2006 | 03:57 PM
Allnbrgdn's Avatar
Default RE: 99' Ford Explorer starting issues ?
Another friend said the same thing, is it true that you can take it off clean it and re-install it, and if so what would be the best cleaner, carb cleaner ?
  #12
Old 08-08-2006 | 04:18 PM
94 4x4 ranger's Avatar
Gumout I think is the best.
  #13
Old 08-11-2006 | 02:58 PM
Allnbrgdn's Avatar
Thanks!
  #14
Old 08-16-2006 | 03:18 PM
Allnbrgdn's Avatar
do i need a ohv IAC ?
  #15
Old 08-16-2006 | 06:20 PM
Mulletman's Avatar
Replace the IAC valve and your problems will be solved. A new Ford replacement part will be around $80.00
  #16
Old 10-11-2006 | 10:52 AM
redskins13's Avatar
definitely replace the IAC valve....and definitely do it yourself. I was having the same trouble just 2 weeks ago and that turned out to be the problem on my '95....cost me about 40-50 I think for the new valve, and was a CINCH to replace...took literally like 3 minutes...2 screws/bolts and it's off and back on.
  #17
Old 10-11-2006 | 12:02 PM
Ramrod48's Avatar
if it can be cleaned , why replace it ??? I do my throttle plates an IAC once a year, along with a can of seafoam
  #18
Old 10-11-2006 | 02:07 PM
redskins13's Avatar
actually you may be correct, however mine was definitely bad....sea foam, injector cleaner, all that stuff didn't help. I used a multi-meter to test the voltage, resistance, etc. and they were no good, that is how I knew the valve was bad and that I actually needed to replace it. Does this make sense Ramrod48? Or did I **** away $50.00?
  #19
Old 10-11-2006 | 02:21 PM
Ramrod48's Avatar
nope sounds like you got it,,
Solar07
08-27-2023 07:36 PM
dwarber
11-04-2009 12:12 PM
Joe Feds
08-19-2009 07:33 AM
Accordman
05-05-2008 11:25 PM
grnded
12-01-2006 05:40 PM
Quick Reply: 99' Ford Explorer starting issues ?
