abs light?
Old 03-19-2005 | 11:04 PM
redfish32's Avatar
Default abs light?
hey folks, i just bought a 2000 explorer with sohc v-6.whats the usual problem with the abs light coming on? do i need to take and have it scanned or is there a sensor that i can replace?any help would be thankfull.
Old 03-20-2005 | 11:31 AM
Patrick's Avatar
Administrator
Default RE: abs light?
with some newer vehicles, there is a monitoring system that triggers the abs light when the brake fluid is low. i would first have a look at the fluid, and if everything is ok, it could also be coming on because you have very thin brake pads, or possibly, but less likely, rotors. if everything there looks good, then it is likely an ABS issue, and you would have to have it scanned to diagnose the problem.
Bob Lobblaw
04-09-2009 09:00 AM
Justin7666
04-11-2008 02:04 PM
Hutch64
05-31-2007 09:21 PM
Quick Reply: abs light?
