BETTER GAS MILEAGE
Old 03-04-2007 | 03:21 PM
braydee0521's Avatar
Default BETTER GAS MILEAGE
I have a 1999 Ford Explorer and the gas mileage I get is horrible. I have replaced fuel filter, plugs, wires, air filter, idle air control valve. What else can I do to help with the gas mileage? Itidles first thing on cold mornings like crap. Hard to keep running. It did notidle bad during the summer and warmer months.
Old 03-04-2007 | 03:27 PM
Default RE: BETTER GAS MILEAGE
What kind of mileage are you getting? Any CEL?
Old 03-04-2007 | 03:42 PM
Yes the cel is on. When I did a test on it the test said idle air control vale which I replaced. It idles like crap in the cold months and never had a problem with it in the summer.
ORIGINAL: Hayapower
Old 03-04-2007 | 04:23 PM
goinstrong's Avatar
If you replaced the valve did you reset the computer? Disconnect the battery cable (maybe both one at a time and clean them) then reconnect. This should reset your computer.
Old 03-04-2007 | 05:15 PM
Ihave reset the computer. The cel light came back on and it idles rough still. I did not have a problem with the idling during the warm months and now that its cold it does not idle right. What to do about gas mileage? I got a1995 gmc 350 z71 and it gets alot better gas mileage than my wifes explorer.
Old 03-04-2007 | 05:59 PM
goinstrong's Avatar
Do you have high mileage on the engine? What gears are in the rear? Do you have 4 wheel drive and are you driving in 2 wheel drive high normally? What engine do you have?
Old 03-08-2007 | 10:28 PM
The truck has about 80,000 miles the engine is 6cyl 245E 4.0L EFI SOHC. Yes I drive it in 2 wheel high. It is 4 wheel drive. As far as the rear gears not sure.
Old 03-10-2007 | 06:04 AM
fordstang's Avatar
I have a 96 Explorer and just posted something similar to yours, except my has no power. I was having the same problem with the idle in the cold, check your temp sensor and thermostat. When I replaced mine, the cel stayed off and it would idle fine in the cold...good luck.
Old 03-11-2007 | 11:20 PM
Where exactly is the temp sensor located? I am not a mechanic so make it as simple as possible please.
Old 03-12-2007 | 12:28 AM
ECT location..
[IMG]local://upfiles/6756/3D4B0FEC37404D00A9005E8C46CC2800.gif[/IMG]
