Check Engine
Old 01-15-2008 | 07:27 PM
Naked and Famous's Avatar
Default Check Engine
98 4L 210km.
Check engine light came on the other day, and a friend suggested putting in some supreme fuel. Sure enough 10 minutes later the light went off. What with that? Oxygen sensor?
I'm going to pick up an obdii code reader, but is there any sequence of buttons I can press to get a readout in this vehicle?
Old 01-16-2008 | 11:45 AM
oldtimer35's Avatar
Default RE: Check Engine
More than likely, if the lite comes on and goes off after a bit, it is the O2 sensor starting to go out. Putting different fuel in it probably didn't really affect it, the sensor started cylcing again and that turned the lite off.
Old 01-16-2008 | 05:30 PM
Thanks for the reply. I will replace sensor soon.
Old 01-17-2008 | 10:10 AM
oldtimer35's Avatar
You need to have the code read because there are two upstream and two downstream sensors. It is probably one of the two upstream ones. Those are the ones closest to the engine.
93redxlt
03-18-2010 05:44 PM
farris1307
09-09-2005 05:59 PM
basketbjones
08-30-2005 11:16 AM
johnny2003
08-21-2005 11:34 PM
bluemq1
05-16-2005 09:06 PM
