Cold Engine Idle
Old 07-22-2008 | 02:05 PM
CCinKC's Avatar
Default Cold Engine Idle
1997 Ford Explorer - 5.0 AWD
Won't idle (or drive properly) when the engine is cold. The AC Receiver Drier was JUST replaced and now I am experiencing this problem; as itdidn't happen before the repair. Is it possible that something was knocked loose during the drier install?
No check engine light and drives perfect at normal operating temperature.
Thanks in advance for your reply(s)
Chris
Old 07-24-2008 | 10:33 AM
kaboom10's Avatar
Default RE: Cold Engine Idle
Did they disconnect the battery for the install? If so you need to drive the vehicle around for awhile to let the ECM relearn. If not disconnect the battery for 20 minutes then reconnect and drive it around for 20 miles so it can relearn.
rdonaphon
07-09-2010 08:56 PM
jimmijones
01-04-2010 07:01 AM
grefra
01-31-2008 04:41 PM
john2windows
01-21-2006 12:47 PM
mikeb
11-10-2005 04:09 PM
