Combination Pad on Door
Old 02-28-2009 | 03:17 AM
quinttheman's Avatar
Default Combination Pad on Door
I am a former Aerostar owner and just purchased a 2000 Explorer without an owners manual. I would like to know how to set the combination keypad on the driver's door. Any information is greatly appreciated.
Old 02-28-2009 | 07:40 AM
JDisney's Avatar
Your original factory setting for this is stamped on the inside of the left rear fender and is accessable through the jack access panel. You may need a mirror to get to it. Even if the code has been changed the original will always work. If you will e-mail me @ jdisney@windstream.net I will scan the instruction for programming for you.
Good Luck with your Explorer
Old 02-28-2009 | 10:57 PM
I looked and could not locate it even with a mirror. Is it near the front or rear of the vehicle? Also I emailed you just in case.
Old 03-02-2009 | 08:42 PM
Thumbs up I found it!!!
The code is located in the inside panel in the jack area. I went to wikipedia and they had step by step instructions. The code is actually on the control module for the door locks. You have to unscrew it and pull it back to see it. It is impossible to use a mirror because the clearance is very tight. Thanks a bunch for the owner's manual.
andy1865
01-28-2008 01:48 PM
dandd1214
09-15-2007 05:19 PM
rcode
05-30-2006 02:52 AM
dandd1214
05-07-2006 04:30 PM
flboy1025
04-13-2006 04:02 PM
Quick Reply: Combination Pad on Door
