Driver door lock & security alarm
Old 09-24-2012 | 12:07 AM
Skysarge's Avatar
Default Driver door lock & security alarm
1999 Model XLT 4wd
Driver door was difficult to unlock with key.
Now key will not unlock door, just turns back and forth no resistance or "click" to indicate lock is operational.
Tried keyless (number code) entry. Rapid clicking can be heard, but door does not unlock. Pass door unlocks with key. Will need to enter car through pass door or leave car unlocked, Latter not good idea obviously.
Also, car alarm started going off intermittently. Turned off with switch provided, short time later came back on. Turned off, turned ign switch to acc, then off as per owner's manual. Same thing again.
Got spare switch, turned off alarm. Seems to Be OK.
Anyone want to weigh in on these?
Thanks in advance,
Skysarge
Old 09-24-2012 | 07:28 PM
yorky's Avatar
I can't help with the alarm but with the door i have to same problem. with mine the rod that connectes the tumbler to the lock keeps popping off most likely due to age and the road dust that got into the door over the yrs (got a 2000) i solved mine by reattaching the rod, sprayed the higby with wd-40 (might want to use silicone spray for odor reasons) and use my keyless remote all the time now since i know if i use the key it will still pop the rod off as its only a plastic piece that holds it
Old 09-25-2012 | 01:50 PM
Skysarge's Avatar
Thanks, will take a look at that.
Skysarge
MWenckowski
11-21-2011 07:28 PM
Esully
News, Updates and Announcements
10-23-2011 11:41 PM
jcjhl69
03-22-2011 08:14 AM
gschutte
04-04-2008 08:00 PM
cwalk
05-11-2006 05:42 PM
Quick Reply: Driver door lock & security alarm
