Explore won't start after long block swap
1991 Ford Explorer - I swapped out the long block and can't get it to start. Pulled scan codes and have:
51 engine Coolant Temperature ECT sensor -signal voltage too high
54 Air Charge Temperature Senor or Vane Air Temperature VAt sensor - signal voltage too high
63 throttle Position snesor - signal voltage is too low
Does anyone have any idea of what these mean and what to do to fix them? Could these be causing it not to start?
RE: Explore won't start after long block swap
good day before anything try the automatic gas shut off located passenger kick panel toward firwall just press the red button on the
-switch .-
p.s if you are looking for ford & lincoln suv used parts . we exclusivly dismantle explorer's expedition's & navigator's for past 10 years
give us a call im sure we can help mike or john 818-767-0316 or fax us at 818-767-0346 or email us @ rainbowauto@sbcglobal.com
-switch .-
Ctwngrl07
06-19-2012 07:16 PM
Cajunle
07-05-2008 10:36 PM
spenni1
04-24-2006 01:04 PM
