explorer 1993 questions
Old 01-12-2008 | 05:14 AM
gixxer32404's Avatar
Default RE: explorer 1993 questions
ok, so I removed instrument panel cluster. Do I have to get cluster recalibrated since I disconnected guages and replaced the 194 bulbs? I also checked the ports for fuel, and temp guage and it lit up one out the 3 ports per guage. So I'm pretty satisfied that the fuelguage problem is the sending unit or float. So I plan to drive to lower my fuel then drop tank today or tommorrow and replace strainer, pump, float andsending unit as oneassembly.
  #12
Old 01-12-2008 | 10:40 AM
oldtimer35's Avatar
Just plug everything back in and reinstall the cluster, be the same as before you removed it. Luck on dropping the tank, just be careful and it will go ok.
  #13
Old 01-13-2008 | 08:57 PM
replaced fuelpump,sending unit, float it's fixed now.the quick connect for fuel lines are not quick.and a pain in the ***.
  #14
Old 01-14-2008 | 01:07 PM
oldtimer35's Avatar
They are quick if you have the right tool. Glad it's fixed.
  #15
Old 01-26-2008 | 12:56 PM
i bought a tool from advance and auto zone........but the prongs inside fitting was bent holding fitting on,also . what's the right tool?
  #16
Old 01-28-2008 | 03:08 PM
oldtimer35's Avatar
Forgot the part number for the tool, but it fits over the fuel line and slides up into the connector. Sometimes it is stubborn and you have to push the line toward the connector and force the tool into it, then it will come off.
RickE33
03-02-2014 05:55 PM
Drivin
06-24-2011 02:31 AM
kimuraTheDodgfan
07-07-2008 10:50 PM
Green_Eye_Gurl2
05-15-2006 07:37 PM
Green_Eye_Gurl2
05-15-2006 05:17 AM
