explorer sport trac valve body gasket help!
Old 06-03-2015 | 12:27 PM
DrakeOmancer's Avatar
Default explorer sport trac valve body gasket help!
I have a 2001 ford explorer sport trac. yesterday i replaced the valve body gasket on the trasmission. I watched videos on youtube how to do it by other mechnics. well i replaced it all with no problems but now my ? is after I replaced it now the truck wont go in to any gear at all its stuck in park and wont go to any gear at all. is there something i could of done wrong to cause this because befor I replaced it it went in gear fine just wouldn't go in gear when push the gas.
my thoughts maybe screw is to tight some where? or do you have to bleed it how much trans fuild needs to be back in it? idk something went wrong when replacing it maybe the gasket is off lined? plz help me
Thanks for n e help
Old 06-04-2015 | 08:00 AM
There must have been some reason for replacing the gasket, whatever it was.
Unless there is a particular reason for using a different gasket you ALWAYS lay the old gasket over the new one to make sure they are exactly the same. Did you do this, if not there could be a difference. If you did not replace the fluid lost during the change, that needs to be corrected.
Make sure all the pins for the electrical plugs are in the correct position, sometimes they can get pushed out when installing the plugs.
explorerman
05-10-2016 12:56 PM
Towguy76
05-22-2013 01:01 PM
Timbo
04-18-2013 12:39 PM
only1bigdaddyo
02-18-2013 12:19 AM
sportmo
10-21-2008 02:03 AM
