Failed Inspection(Parking Brake)
Old 01-26-2008 | 09:37 PM
Coles's Avatar
Default Failed Inspection(Parking Brake)
The subject pretty much says it all. I took my 98 XLT for inspection and failed. I was told that the parking brake isn't holding the vehicle. Any suggestions? TIA
Old 01-28-2008 | 02:19 PM
oldtimer35's Avatar
Default RE: Failed Inspection(Parking Brake)
Rear disc brakes? The shoes are on the inside of the rotors. I believe the only adjustment on this system is like adjusting old drum brakes. There should be an access hole in the back of the backing plate on the bottom. You can adjust the brakes through the access hole with a spoon adjuster, making sure you don't get it too tight, because backing them off is no fun.
Old 02-03-2008 | 09:39 AM
Mulletman's Avatar
I bet the rear parking brake lining has come unbonded and will need new P.Brake shoes installed.
Old 02-03-2008 | 07:29 PM
Coles's Avatar
Do you guys think it would cost me an arm and a leg to get this fixed???
Old 02-03-2008 | 08:05 PM
Mulletman's Avatar
Maybe just one ********.
I would guess around $200.00 for total if it is a rear P.brake shoe replacement.
Old 02-04-2008 | 11:07 AM
Coles's Avatar
LOL Thanks
Old 02-04-2008 | 03:05 PM
oldtimer35's Avatar
Are you getting any noise from the rear brake area? This would indicate a lining that has come loose. Otherwise, adjust them .
Old 02-08-2008 | 06:01 PM
Coles's Avatar
Nope, nonoise coming from the rear..
Old 02-09-2008 | 11:32 AM
oldtimer35's Avatar
So, have you tried to adjust the emergency brakes? Just turn the screw a couple of turns and see if it trys to hold. [sm=mail.gif]
Paul Ledoux
06-12-2015 06:02 PM
ron barbrey
04-05-2014 04:43 PM
makuloco2000
03-05-2014 11:42 AM
cat5656
06-29-2011 02:44 PM
